Canopy Glue
I can recommend this product : https://www.deluxematerials.co.uk/gb...243900111.html
The absolute best canopy glue i have ever used
https://www.deluxematerials.co.uk/gb...243900180.html
set your canopy in place using cylinder magnet, once you are confident you have it positioned correctly apply a tiny bead of this glue around the perimeter and let it dry overnight and you will have an incredibly strong joint. It dries absolutely clear too.
My Feedback: (40)
This is the best stuff I have used: http://www.epoxysupply.com/adhesives...l-clear-epoxy/
Low viscosity, 30 minute working time, cleans up nicely with isopropyl alcohol before curing and dries clear.
Craig
Craig
My Feedback: (8)
I found an adhesive that is outstanding for gluing almost anything to anything, especially canopies. It is E6000. Can be found in hardware stores and craft stores. A far better adhesive than silicone and RC56. Dries clear but remains flexible after curing. Cleans up with water before it cures. Any smears can be cleaned up after cure by simply rolling it up under your finger. Where it really shines is gluing a non-porous item to a non-porous surface!
