Go Back  RCU Forums > RC Airplanes > Questions and Answers
Servo movement after the fact
Old 02-25-2017, 09:30 AM
gbfan
Default Servo movement after the fact
Hi guys,,
I have some servos that when radio stick movement is activated to the farthest point suddenly...
the servos move to the end point and stop and then a 1/2 second later moves a
tiny bit more in the same direction. I have tried changing the end point . That did not help.
They are on 6 volt and have proper voltage. They are metal gear and digital . my
receiver is analog futaba . I had this same problem with a digital receiver..
Lets not just say they are cheap servos what causes this.
How can I fix this
David
Old 02-25-2017, 03:02 PM
All Day Dan
All Day Dan's Avatar
David, plug your battery and servo directly into the receiver and see what happens. Dan.
Old 02-25-2017, 05:54 PM
gbfan
Dan
So you want me to by pass the power switch ? easy enough
Ok still does it but I cant by pass the servo reverser I have in it
It is brand new
Old 02-25-2017, 07:00 PM
All Day Dan
Wires, connectors, servo reverses, power distributors, anything can be the source of a failure. The easiest way to find out the cause of the failure is to isolate it. Maybe it's the receiver. Start removing, exchanging, replacing, you name it any thing that is in series from your transmitter joy stick to the control horn to find the problem. It may be the transmitter or even your new servo reverser. Post your results. It's somewhere. We can all benefit from it. Dan.
Old 02-25-2017, 09:55 PM
JohnBuckner
JohnBuckner's Avatar
Servo reverser devices can be problematical new or not. Remove the device and test without reversing the servo to confirm it is not the reverser.
John
Old 02-26-2017, 06:27 AM
kenh3497
kenh3497's Avatar
A club mate was having a jittery throttle servo. LONG story short, it was the TX (throttle stick) that was the problem.
Ken
