Lipo Charger and a Battery with integrated BMS
Hello RCU community. As above stated, I have a charger which has a failsafe function; without detection over the balancer port, it won't charge. The problem is that I have two batteries with the integrated BMS (LiFePo4), without balance connection of course. Is there some way to trick the charger into thinking that the load is there? Some jumper solution?
Thanks, Marko
Thanks, Marko
Thanks, Marko
Thanks, Marko
I use them on my 1S and 2S LiPo packs that don't have balancer ports to charge on my iCharger 308 Duo and other "smart" chargers.
You google-search for "charging 1S LiPo on smart charger" and find a few schematics and some places that sell them pre-made.
Life Charger
This Chager is able to charge Life bateries without the Balancer cable.. Another point, charging without balancer cable is dangeraous , because if you chosse the wrong batery configuration can cause damege and Fire the batery. Take care!!!
